Hi!
In Aruba Central I have configured 3 SSIDs. I know that if you have different clusters with same SSIDs, you should specify MDID number for each SSID (in fast roaming 802.11r settings), but if I have one cluster with multiple SSIDs, should I leave default value in MDID field which is 1 for all SSIDs.
Also recently for one of the offices, which had one SSID and worked well, I have enabled 802.1r. The next day I got call that users can't connect or dropping off. In Central I saw very high authentication errors. I've disabled 802.1r and after that it worked just fine.
Thanks!
