  • 1.  Fetching configs
    Posted Apr 20, 2012 07:35 AM
    I am using 7.4.7 of Aiwave and am having a problem fetching updated configs from IAP 105 AP's. When I run a fetch from my group, I receive the message in the config below:
    ! Template created from vtlsafl01 (6.1.2.3-2.0.0.4_32946) at 4/20/2012 7:21 AM
    ! based on config fetched at 4/20/2012 7:01 AM"
    The problem with this is the "based on config" part. The config that this fetch is based on is the old config and NOT the newest config that I want to be fetched. I have tried creating multiple templates yet the based on date stays the same. What am I missing here?
    TJG
  • 2.  RE: Fetching configs
    Posted Apr 20, 2012 12:13 PM
    Within that group, are there other IAP templates, perhaps with different firmware restrictions?
  • 3.  RE: Fetching configs
    Posted Apr 20, 2012 05:22 PM
    When you import a new template for Instant it uses the most recently fetched config (as opposed to fetching a new config on the spot). Try going to the Virtual Controller's audit page, clicking audit, then importing the template again once the audit completes.
  • 4.  RE: Fetching configs
    Posted Apr 20, 2012 07:43 PM
    Thanks for the reply, all is well now.
