Comware
FF 5700 IRF issue (cancelling bind)
  • 1.  FF 5700 IRF issue (cancelling bind)
    Posted Apr 18, 2016 07:50 AM
    Hi Guys,
    I have 2 FF 5700 switches for IRF and use below Command Line.
    system-view
    irf member 1 priority 32
    interface ten-gigabitethernet 1/0/39
    shutdown
    quit
    irf-port 1/1
    port group interface ten-gigabitethernet 1/0/39
    quit
    undo shutdown
    When i try to undo shutdown, it prompts:
    Bind all interfaces in the same group to one or two IRF ports or cancel the bindings on all of them.
    This is a new switch and i have reset current-configuration.
    Any idea what went wrong?
    Thx
    #ff5700
    #irf
    #switchHP
    #HPSwitch
  • 2.  RE: FF 5700 IRF issue (cancelling bind)
    Posted Apr 18, 2016 09:25 AM
    Hi Dani,
    on the 5700 there are four physical Interfaces connected to one ASIC, all four ports in one group have to be either IRF ports or all normal ethernet ports (e.g. ports 37-40)
    Here is the relevant excerpt from the 5700 IRF config guide:
    When you use 10-GE ports for IRF connection, follow these restrictions and guidelines:
    • The 10-GE ports are grouped by port number in order, starting from 1. Each group contains four ports. If you use one port in a group for IRF connection, you must also use all the other ports in the group for IRF connection. However, you can bind the ports to different IRF ports.
