Comware
Fiber Link Network Configuration
  • 1.  Fiber Link Network Configuration
    Posted Jul 25, 2022 02:58 PM
    I was able to route traffic from the OPS switch (5406zl) to the Conroe firewall (Left Side) 0/0 >> 10.0.0.100 through VLAN tagging, however I need to route 1 VLAN (172.16.90.0/24) to the Woodlands firewall (192.168.10.1). If tried a static route, which didn't work.
    I've read about policy based routing, which requires v2 modules (I have 3 v1's and 3 v2's), so purchasing more modules will be required, and it's not a 100% this will resolve my VLAN routing issues.
    I've also read about access lists for VLAN traffic. My default gateway is 192.168.10.1 on the OPS switch and default route is 0/0 >> 10.0.0.100. Only the 1 VLAN needs a separate route, but how to distinguish it from the default route?
    Attached is a diagram. I can also add the OPS switch config file if needed.
