Similar question here. That may help...
Original Message:
Sent: Oct 31, 2024 07:30 AM
Subject: fidelio Opera controller integration
Dear Forum Members,
I'm currently working on a project involving Aruba ClearPass and Opera integration. My client aims to authenticate users using their room number and last name.
I've noticed that some of you have implemented similar setups. I'm reaching out to seek guidance on crafting a workflow that allows users to authenticate through Opera using this specific information.
While I have successfully integrated Opera and can access the room number and last name data, I'm uncertain about the best approach to link this information to the ClearPass authentication process.
I'd appreciate any insights or suggestions on how to verify user credentials against Opera data when they input their room number and last name.
Thank you for your time and assistance.
Original Message:
Sent: Feb 22, 2016 08:48 PM
Hi Carlos,
Yes they need to purchase the module..... here is what I have on it........ some of the below might have changed so you need to verify the cost....
- Oracle Micros http://www.micros.com/
- Part no: 5009-297
- Name: Clear Pass Guest – Aruba
- Type: WWW/IF
- Cost is set by Micros: Approximately $3500-$4000
