Cloud Managed Networks
  • 1.  Finding out CX Switch Firmware Image Allocation in Central
    Posted 30 days ago
    I am trying to find out which firmware versions are installed on the CX switches via Central. Unfortunately, I cannot see which image (primary or secondary) is active in the GUI or via the API, nor which version is present in the other image. I can only see which version is currently being used.
    Tried the following API requests:
    https://{{baseurl}}/firmware/v1/devices?device_type=CX
    https://{{baseurl}}/firmware/v1/devices/{{serial}}
    https://{{baseurl}}/monitoring/v1/switches
    Always running firmware version is shown, but no glue about image location or other loaded firmware,
    Have I overlooked something?
    Parameters:
    - It is not about 10 switches, but almost 1000 switches, so please no suggestions in which "via CLI on each switch" occurs.
    - Since it is an MSP account, there is no CNX toggle
    Thanks in advance!
    Greez,
    Uli
  • 2.  RE: Finding out CX Switch Firmware Image Allocation in Central
    Posted 24 days ago
    Hi Uli,
    With the current version of Central this is not possible. However, with New Central this info is available via the API. I don't have all the details but I believe also for the UI this is planned.
    New Central / CNX toggle can be enabled on MSP (sub) accounts. Please check with your SE.
    You need to use the following API call to get this info: https://developer.arubanetworks.com/new-central/reference/getswitch
    Information that will be returned (only the relevant info for now)
        "firmwareVersion": "ML.10.15.1020",
        "serial": "<removed>",
        "configStatus": "Synchronized",
        "upTime": 1659575393,
        "rebootTs": 1749029639,
        "manufacturer": "HPE ANW",
        "firmwareBackupVersion": "ML.10.13.0005",
        "deviceName": "6200",
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 3.  RE: Finding out CX Switch Firmware Image Allocation in Central
    Posted 20 days ago
    Hi Willem,
    Thank you very much!
    But still we cannot see which partition is used, correct?
    Nevertheless, I contacted our Partner SE to get the toggle. In the meantime I have access to another tenant with activated CNX and test this out.
    Greez,
    Uli
  • 4.  RE: Finding out CX Switch Firmware Image Allocation in Central
    Posted 18 days ago
    Currently I see firmware and backupfirmware in the API response. The Firmware management for New Central is almost ready I've understand. Best is to contact your Partner SE so they can check with PLM about this specific request. In general, based on what I've seen, Central will automatic select the primary and backup partition. For example, if partition 2 is currently the active one and you start an update via Central, partition 1 will become the new active partition.
    Willem Bargeman
    ACEX #125
  • 5.  RE: Finding out CX Switch Firmware Image Allocation in Central
    Posted 18 days ago
    Hi Willem,
    Thanks a lot! That should do it if Central takes care of choosing the right partition. So, using CNX in the near future eliminates the cause of my request although I would like to have kind of a possibility to choose the partition perhaps in the way AFC has it. Perhaps it's German mentality... ;)
    Greez,
    Uli
