  • 1.  Firewall policies of two roles applied to client traffic?
    Posted Aug 15, 2017 03:09 PM
    We have acquired pefng licenses for our controller with arubaos 6.5.3.1 and installed it today. Everything was working fine before the installation of the licenses. After the installation, configuration was extended with standard roles etc. and everything looks the way it should be.
    We use dot1x with radius authentication for the wireless connection. Clients can still authenticate successfully and are assigned the dot1x-default-role as set in the aaa profile. However, the only traffic passing through after authentication is the traffic allowed for user-role logon (ping, dns).
    After much searching and testing I have added logging to the allowall access-list and added an additional access-list with logging to the logon role. To my big surprise I now can see that all client traffic is first permitted by the allowall and then denied by the logon role which is consistend with what I see on the client.
    Here an extract of the configuration with a test aaa profile.
    user-role logon
     access-list session logon-control
     access-list session captiveportal
     access-list session vpnlogon
     access-list session v6-logon-control
     access-list session denyalllog
    user-role authenticated
     access-list session global-sacl
     access-list session apprf-authenticated-sacl
     access-list session ra-guard
     access-list session allowall
     access-list session v6-allowall
    ip access-list session denyalllog
      any any any deny log
    ip access-list session allowall
      any any any permit log
      ipv6 any any any permit
    aaa profile "Test-aaa_prof"
       authentication-dot1x "dot1x_prof-sps67"
       dot1x-default-role "authenticated"
       dot1x-server-group "Test_srvgrp-bjd43"
    Now the logs show this:
    Aug 15 20:29:23 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {94} TCP srcip=<client-ip> srcport=55645 dstip=17.253.55.206 dstport=80, action=permit, role=authenticated, policy=allowall
    Aug 15 20:29:23 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {95} TCP srcip=<client-ip> srcport=55645 dstip=17.253.55.206 dstport=80, action=deny, role=logon, policy=denyalllog
    show user shows the client in authenticated role. The client can ping any ip address possible, even using dns host names, but nothing else.
    I haven't found any documentation explaining what could be going on. Actually, everything I have read makes me think that a client can only have a single role at any given time, so those logs don't make any sense to me.
    What am I missing here? Why is the logon role firewall policy applied to all traffic even for users in a different role?
  • 2.  RE: Firewall policies of two roles applied to client traffic?
    Posted Aug 15, 2017 03:16 PM
    I would disable the logging and use "show datapath session table <ip address of client>" instead.
    You honestly should not edit the logon (system) role.
  • 3.  RE: Firewall policies of two roles applied to client traffic?
    Posted Aug 15, 2017 03:38 PM
    I did that, too, but output quickly changes thus makes it hard to track. Now I have tried to reduce client traffic to a minimum and it seems there is actually one syn packet getting a response which is dropped.
    Logs:
    Aug 15 21:27:26 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {156} TCP srcip=<client-ip> srcport=56967 dstip=216.58.213.196 dstport=80, action=permit, role=authenticated, policy=allowall
    Aug 15 21:27:26 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {157} TCP srcip=216.58.213.196 srcport=80 dstip=<client-ip> dstport=56967, action=deny, role=logon, policy=denyalllog
    Aug 15 21:27:27 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {158} TCP srcip=<client-ip> srcport=56967 dstip=216.58.213.196 dstport=80, action=permit, role=authenticated, policy=allowall
    Aug 15 21:27:27 2017 neon1 authmgr[4117]: <124006> <4117> <WARN> <neon1 10.25.1.101>  {159} TCP srcip=<client-ip> srcport=56967 dstip=216.58.213.196 dstport=80, action=deny, role=logon, policy=denyalllog
    show datapath session table <client-ip>:
    Source IP       Destination IP  Prot SPort DPort  Cntr    Prio ToS Age Destination TAge Packets    Bytes      Flags
    216.58.213.196  <client-ip>   6    80    56967  0/0     0    0   0   pc0         4    1          60         FDC
    <client-ip>   216.58.213.196  6    56967 80     0/0     0    0   0   tunnel 101  3    2          128        FDYC
    Both are flagged with D. odd. And it also doesn't show this for every connection attempt but only for some. For most connection attempts the first line for the response never appears and the remote server doesn't get anything, i.e. all outgoing traffic from the client is already dropped...
    Well, I saw the increasing hit count in the firewall hits monitoring page of the controller and wanted to know what it is exactly. Adding a policy seemed to be the only way to find out what it is exactly (even though hit counts suggested that the logon role deny and the authenticated permit increased together). And it wasn't meant to be permantent either.
  • 4.  RE: Firewall policies of two roles applied to client traffic?
    Posted Aug 15, 2017 03:41 PM
    You should make your port channel interface trusted.  By default it is untrusted.  Making it untrusted would assign the logon role to it.
  • 5.  RE: Firewall policies of two roles applied to client traffic?
    Posted Aug 15, 2017 04:27 PM
    Just found that, too. That's it. Now it's working. Thanks!
