Wired Intelligent Edge
  • 1.  Firmware corrupted
    Posted Jun 17, 2021 09:17 PM
       Our Aruba 2930M switch firmware corrupted
    How can I troubleshoot the switch
    leyakath muhammed
    Attachment(s)
    txt
    SwitchError.txt   19 KB 1 version
  • 2.  RE: Firmware corrupted
    Posted Jun 18, 2021 11:38 AM
    This is similar to an issue I just had the other day, and the only solution was to call TAC, they have a back door they can log into and zeroized the switch to factory defaults, (hope you have a backup) which will wipe the firmware and the config. then you can reinstall the firmware.
    Hope this helps.
    Christopher Leach
  • 3.  RE: Firmware corrupted
    Posted Jun 22, 2021 06:55 AM
    Hi Liyakath,
    you can give a shot with the following guides to recover the switch:
    HPE documentation: https://techhub.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8162_wb_2920_mcg/content/ch11s11.html
    Guide from another source with some nice screenshots: http://www.ipuptime.net/2012/07/procurve-corrupted-flash-recovery/
    If this is not working for you, follow the Christopher's advice and call the support.
    Stanislav Naydenov
