Yes you can. You will be presented with a field for each AP model that needs a different firmware. You will then supply the fields with the URLs for the upgrade files. See page 19 of the release notes for upgrade procedures:
https://www.arubanetworks.com/techdocs/Aruba-Instant-8.x-Books/Release-Notes/810/Aruba-Instant-8.10.0.4-Release-Notes.pdfExample URL scenario below:
505 = Gemini
515 = Draco
535/534 = Scorpio
577 = Draco
http://172.22.176.58/ArubaInstant_Draco_8.7.1.0_77203_1.bin
http://172.22.176.58/ArubaInstant_Scorpio_8.7.1.0_77203_1.bin
http://172.22.176.58/ArubaInstant_Gemini_8.7.1.0_77203_1.bin
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Oct 12, 2022 06:35 AM
Subject: Firmware Upgrade while different models APs on a single cluster.
Dear Team,
In our organization there are multiple different models access points are running on a single cluster like (Model: 207, 303, 305). In these one AP of model 207 works a master AP and rest of the APs are synchronized. The issue is that i want to upgrade the firmware and can I upgrade firmware from Maintenance --> firmware--> automatically check, option while all of these different model APs are running. Please suggest.
