first rap configuration
  • 1.  first rap configuration
    Posted Dec 12, 2012 07:13 AM
    I would like to configurate a remote AP, but I can't.
    Can I ask to write a step by step guide for this?
    Here is a simple wlan base config and I would like to see a test ssid in my brach office.
    interface 0/8
    vlan 1
    192.168.10.0/24
    192.168.10.150 controller
    vlan 100
    192.168.100.1/24
    SSID
    test -- vlan 100
    Thank you in advance for your reply.
  • 2.  RE: first rap configuration
    Posted Dec 12, 2012 08:41 AM
    I have attached an Aruba guide on how to deploy remote APs , you can pretty start on chapter and it should guide through the initial setup.
    If you get stuck on anything let us know.
    Vic
    Attachment(s)
  • 3.  RE: first rap configuration
    Posted Dec 12, 2012 08:42 AM
    I meant to say chapter 2
  • 4.  RE: first rap configuration
    Posted Dec 16, 2012 12:44 PM
    Thank you vfabian! I will try to configurate.
