  • 1.  Flash space warning
    Posted Oct 28, 2014 05:42 AM
    I am getting RAP whitelist & flash space warning message while loging controller through cli.
    Please find attached screenshot.
    Thank you,
    Nik..
  • 2.  RE: Flash space warning
    Posted Oct 28, 2014 08:38 AM
    You won't see this data on the flash file system as a file; it is within the user DB.  In 6.3 and later, the rap whitelist is stored separate from the local-userdb.  Take a flashbackup of your system (to grab the entire user DB as is in case you ever need to downgrade) then run the following command to cleanout the RAP entries:
    local-userdb-ap del all
