Is there any way to force a URL instead of IP over the split tunnel for VIA VPN?
We have a use case where a 3rd party has only whitelisted our internet facing IPs, when users are on VIA VPN they are blocked because traffic is outside the VPN due to split tunnel ACL and using their own internet facing IP. The problem we have is the URL resolves to 3 different IPs every few days so no way to add the subnets to the split tunnel ACL as the fix would last about 3 days before the IPs are changed to completely new ones.
Just wondering if anyone has had this issue and found a work around?
Andy
