  • 1.  Fortinet and Clearpass
    Posted Mar 13, 2015 03:06 AM
    Hi all,
    Does anybody using fortinet wireless with clearpass for guest self regestration.
    I need some suggestion ..
  • 2.  RE: Fortinet and Clearpass
    Posted Mar 13, 2015 04:34 AM
    Hi Suman,
    Please share your requirements so that, I can give you a better solution.
    Please feel free for any further help on this.
  • 3.  RE: Fortinet and Clearpass
    Posted Mar 13, 2015 04:55 AM
    I am looking for guest self registration in fortinet wireless with
    Clearpass.
    I just checked and saw that they are doing captive portal with internal
    only. [*Captive portal page and user id both are coming from internal DB*]
    There is no option to add external captive portal page, If its there
    please let me know.
  • 4.  RE: Fortinet and Clearpass
    Posted Aug 17, 2017 01:11 PM
    Does anybody integrate a fortigate with Clearpass as radius server?. In the radius test, pass success, But when i put the autentication as captive portal or 802.1x for wifi, The autentication fails.
    With other Radius, server works fine.
    Any idea?
  • 5.  RE: Fortinet and Clearpass
    Posted Jan 02, 2024 08:46 AM
    Edited by Greg_W Jan 16, 2024 10:45 AM
    I have written a guide on how to create a guest network SSID on FortiGate using ClearPass as the external captive portal. As for regular dot1x, any "allow" should work or you can return a valid group back to the Fortigate: Radius:Fortinet:Fortinet-Group-Name
    Edit: The document will be updated here: https://community.fortinet.com/t5/Article-Ideas/Technical-Tip-How-to-use-ClearPass-as-FortiGate-captive-portal/idi-p/292665
    I am currently a Fortinet employee, after 9 years as a Aruba SE.
    Attachment(s)
    pdf
    HowTo-ClearPass Guest.pdf   1.92 MB 1 version
