  • 1.  gateway load balancing
    Posted Dec 05, 2022 01:22 PM
    we have to internet lines and we have aruba MM and 2 MC if there is any way to load balance the traffic to use the 2 internet lines ?
    my core switch is router for the all vlans
  • 2.  RE: gateway load balancing
    Posted Dec 08, 2022 08:52 AM
    If your controllers are running in L3, you may be able to do that with Policy Based Routing (PBR) or more advanced with SD-Branch code on the controllers.
    If, as you mention, you core switch is the router for all the VLAN, then you should create something on your core switch as that is where your routing happens.
