generate wireless disconnect syslog messages
  • 1.  generate wireless disconnect syslog messages
    Posted Aug 14, 2020 03:33 AM
    how can I generate this syslog message?
    Aug  6 14:41:44  authmgr[5486]: <522010> <5486> <NOTI> |authmgr|  MAC=c0:14:3d:cf:b5:df IP=192.168.128.101 User de-authenticated: name=user3, cause=user request
    I already turned on all of the notifications alert but it is still not appearing
    (aruba-vmc-active) [mynode] #show running-config | include logging
    Building Configuration...
    logging security subcat ids level warnings
    logging security subcat ids-ap level warnings
    logging user process authmgr level notifications
    logging user process dot1x-proc level notifications
    logging user level notifications
    logging user process authmgr subcat all level notifications
    logging user process dot1x-proc subcat all level notifications
    logging user subcat all level notifications
  • 2.  RE: generate wireless disconnect syslog messages
    Posted Aug 14, 2020 03:44 AM
  • 3.  RE: generate wireless disconnect syslog messages
    Posted Aug 14, 2020 05:25 AM
    Try this:
    config t
    logging user-debug de:ad:be:ef:ca:fe level notifications
    That is where de:ad:be:ef:ca:fe is the mac address of the user.  You would then type "show log user-debug all" to see the output.
  • 4.  RE: generate wireless disconnect syslog messages
    Posted Aug 20, 2020 04:55 AM
    Hi cjoseph
    still same, no de-authenticated logs appeared. What I am currently doing is to generate login and disconnect system logs like this one
    Aug 6 09:01:59 authmgr[5486]: <522008> <5486> <NOTI> |authmgr| User Authentication Successful: username=user3 MAC=c0:14:3d:cf:b5:df IP=192.168.128.101 role=guest VLAN=128 AP=AP1 SSID=esni-radius-auth AAA profile=esni-radius-auth_aaa_prof auth method=802.1x auth server=esni-radius
    The logs above was generated successfully. No issues.
    but when i try to disconnect the wireless user.  I only managed to generate few syslogs. maybe three times(after hours of testing of logging in and disconnecting in the ssid) . I currently don't know what triggered it but the real problem is that it is not real time.
