Getting 'null' error while adding Mobility Controller (Add device)
  • 1.  Getting 'null' error while adding Mobility Controller (Add device)
    Posted Apr 26, 2013 11:20 AM
    Hope somebody can help me with this
    Getting 'null' error while adding Mobility Controller aruba3200 (Add device) to CPPM 5.2
    I feel in every field with what written in an integration guide and when I click add it holds quite long and then writes in red 'null'
    Any ideas where I can look for a system log or other stuff that could help me to define the problem?
    or maybe there is another integration guide to give me an idea what I did wrong in previous steps?
    Thank you in advance.
  • 2.  RE: Getting 'null' error while adding Mobility Controller (Add device)
    Posted Apr 26, 2013 11:55 AM
    Olena,
    That should not happen.  You should probably open a support case...
  • 3.  RE: Getting 'null' error while adding Mobility Controller (Add device)
    Posted Jul 03, 2013 10:30 AM
    There is a pathch "ClearPass 6.1 Cumulative patch 2" on the support site that fixes this issue.
