Comware
  • 1.  Gigabit LX module error in 4000m
    Posted Aug 12, 2003 03:28 AM
    Hi!
    My question is about 2 Gigabit LX modules, they don't really want to build up a connection.
    I have 2 devices:
    HP 2512 and HP 4000m, both with LX modules, connected with multimode fiber, length about 330 meters, using mode conditioning patch cord both sides (correctly installed :-).
    2512 details: Firmware revision:F.04.08, ROM Version:F.02.01
    4000m details: ROM stamp:C.06.01, Image stamp:C.09.16
    And somehow there is no link between these ports. I've tried an other (Lucent) gigabit device, and that worked with 2512, but I couldn't try the Lucent with 4000m.
    Both switch can see the 1000lx ports without any attention, although 4000m sometimes logged, that Module/Configuration mismatch, but after a reset it could initialize the card.
    So, I'm asking whether is there anything i did wrong, or i don't know?
    Sanyig
  • 2.  RE: Gigabit LX module error in 4000m
    Posted Aug 12, 2003 03:33 AM
    are both ports forced to same settings?
    you try without mode conditioning patch cord? Lenght is less than 500 meters... ;-)
  • 3.  RE: Gigabit LX module error in 4000m
    Posted Aug 12, 2003 03:41 AM
    I know that i can set Fdx/Hdx and what else?
    >you try without mode conditioning patch cord? >Lenght is less than 500 meters... ;-)
    Yes it is less, but we have a passive extension somewhere in the 330 meter, and as i know mode conditioning cannot make it worse than it is, but in the first days we didn't have MCPcord.
  • 4.  RE: Gigabit LX module error in 4000m
    Posted Aug 12, 2003 03:48 AM
    mode is set to 1000LX, or Auto....?
    check that is set to 1000LX and not to auto.... this can cause connectivity problems
  • 5.  RE: Gigabit LX module error in 4000m
    Posted Aug 12, 2003 05:20 AM
    I think, that it's auto...
    By this time, i could borrow a Procurve 1600m for testing, but it asks for username, and the owners doesn't know the password.
    Is there any manual about HP Procurve restoring factory defaults?
  • 6.  RE: Gigabit LX module error in 4000m
    Posted Aug 12, 2003 06:12 AM
    You can Reset the Password by pressing the Clear button for about 10 seconds.
    On the LX link issue. the 2512 defaults to Auto while the 4000M/1600m to 1000FDX. Just change either side although I would suggest Auto as that protect for half a link failure (sort of like Cisco's UDLD) so in case TX on 1 side fails the link on BOTH switches will go down thereby preventing a black hole.
    2512 firmware should be upgraded to F.05.17.
    Thanks, Ardon
  • 7.  RE: Gigabit LX module error in 4000m
    Posted Aug 14, 2003 01:24 AM
    It seems, that my problem is solved by setting AUTO (not 1000LX) for the port...
    Thanks for everyone!
    Gabor
