  • 1.  GSR Metadata Variables
    Posted Apr 16, 2016 06:06 AM
    In Guest Self-Registrations Pages there are variables used, such as "$gsr_metadata.register_page" which is the register page name. Is there a list of all variables available that you can use in the Self-Registrations Pages ? I found a couple of them on the forum.
    Basically I'm trying to include the variable "Register Page Title" into the header of Register page, Login Page, Login Receipt, ...
  • 2.  RE: GSR Metadata Variables
    Posted Apr 18, 2016 11:18 AM
    What you can do is enter {debug} into the self-registration page header field.
    That will pop up a screen with all set values if you open the registration page:
    Make sure you allow popup windows through any popup blockers.
    Does this help you any further??
  • 3.  RE: GSR Metadata Variables
    Posted Apr 18, 2016 11:29 AM
    Thanks Herman ! Exactly what I was looking for.
