Do you have a different product number? APIN0505 is a regulatory code used for different types of accesspoints. Example AP-505-RW... or share a photo of the (white!) stickers that are applied on the back (and from factory top as well) of the AP.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 07, 2025 07:50 AM
Subject: Guest Access Using mobile number only for OTP Authentication
How do I configure Guest users to connect to the guest SSID using Aruba APIN0505, using their mobile number only for OTP Authentication instead of username and password?
