  • 1.  Guest Provisioning (Captive Portal) Aruba Controller
    Posted Jun 02, 2017 01:50 PM
    Hi All,
    I am going to configuring Guest Access from Controller. When i did and try to connect to the Guest SSID then the controller redirect to me the controller not to captive portal page. Default Role in L3 Authentication i make "guest", in AAA initial role i make "logon". Can any body tell me what i will do to fix this issue.
  • 2.  RE: Guest Provisioning (Captive Portal) Aruba Controller
    Posted Jun 03, 2017 04:01 AM
    Have you assigned the Captive Portal Profile to your Initial role in the AAA profile?
    If you post the output of the below where XXXX is your initial (probably the logon role)
    #show rights XXXX
    (sent from a mobile device)
  • 3.  RE: Guest Provisioning (Captive Portal) Aruba Controller
    Posted Jun 03, 2017 12:54 PM
    Hi Zalion,
    Attached is the output file you requested.
    Attachment(s)
    txt
    Show rights.txt   3 KB 1 version
  • 4.  RE: Guest Provisioning (Captive Portal) Aruba Controller
    Posted Jun 03, 2017 12:58 PM
    Following are the roles which i configured in AAA and L3 Authentication profile.
    Initial Role in AAA profile = guest-logon
    Default Role in L3 Authentication (Captive Portal) = guest
  • 5.  RE: Guest Provisioning (Captive Portal) Aruba Controller
    Posted Jun 04, 2017 02:03 AM
    If you run the below, do you see the Captive Portal profile assigned?
    show rights guest-logon
    Here's an example of my inital role showing the Captive Portal profile being assinged (see the last line). It is using the default Captive Portal profie.
    (Lab620) #show rights guest-logon
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'guest-logon'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Number of users referencing it = 0
     Periodic reauthentication: Disabled
     DPI Classification: Enabled
     Youtube education: Disabled
     Web Content Classification: Enabled
     ACL Number = 9/0
     Max Sessions = 65535
     Check CP Profile for Accounting = TRUE
     Captive Portal profile = default
  • 6.  RE: Guest Provisioning (Captive Portal) Aruba Controller
    Posted Nov 18, 2019 11:24 PM
    I have the same problem. What is the solution? I create WLAN and create guest and open access rule as logon. How should I do?
