Hi Owais,
One example is that the form's window top bar I have replaced using following style:
TH.nwaTop { background-color: #007AC9;
background-image: url(public/tht20_mod.gif);
Where I have created the tht20_mod.gif in Gimp and it gives a different color gradient frame. Upload it to public files and that is it.
You can also create tag identifiers in the page code (Header or Footer parts) and style them in the custom skin configuration. E.g. I have created a div for the form so that I can center it. I added the <div id="CPForm"> in the Header HTML section's end and the </div > in the Footer HTML section's beginning because the form is in-between. I gave the #CPForm ID name to it and styled it in the custom skin CSS.
#CPForm{width: max-content;
padding: 0px;
margin: auto;
background-color: #F0F0F0;}
Regards
Istvan
Original Message:
Sent: Jun 13, 2025 06:57 AM
Subject: Guest Skin for Self Registration - possible?
Thanks Istvan thats exactly what i wanted to confirm, i did check the page via developer tools and tried to do the css using the form name etc but i didnt work properly, but if thats the only way to go, i will try harder this time ��
Best Regards
Owais Iqbal
CCIE#37956 | ACDX
Technical Consultant - Aruba Networks
Mob/Whatsapp: +92-321-2960496
Original Message:
Sent: 6/13/2025 5:17:00 AM
Subject: RE: Guest Skin for Self Registration - possible?
I have customized web login using own CSS styles. What I have done, I used the Custom Skin 1 in Plugin Manager and edited it. It has a CSS styles part and you can also set certain parameters there like colors.
If you want to know class names the best way is to test the page in Firefox and go to Developer Mode (F12) and investigate the HTML code. You can see there all IDs and classes. The form ID however contains a generated identifier so if you want to use that in javascript you have to use _form_name variable instead. Analyzing the HTML code in a browser helps a lot.
Regards
Istvan
Original Message:
Sent: Jun 12, 2025 04:31 AM
Dear Experts,
I can complete tweak and supply my own login form for web logins (separately or even in self registration workflow). However i cannot get my head around the guest registration form and page. Can we provide our own styling completely to give it a completely new look? i dont want to use Galleria. I know about blank and custom skins but to apply CSS, i need to know class names of Forms mainly. I can provide custom CSS classes to every field but what about the form itself?
Owais101
