Aruba Apps
  • 1.  Guest SSID authentication error
    Posted Mar 03, 2021 12:53 PM
    We are using clearpass for guest authentication
    While connecting on guest SSID users are unable to connect .what should I check on clearpass ?
    Please guide me I am new to this technology
    Shivam Ojha
  • 2.  RE: Guest SSID authentication error
    Posted Mar 03, 2021 01:12 PM
    There are a lot of information needed, in order to help you.
    1. What type of Wireless Controller are you using?
    2. If the SSID is configured as Open with Captive Portal, if you have a pre-authentication ACL, is it allowing the path to see Clearpass (in order to show Username/Password).
    3. Did you configure the correct service for Guest Authentication.
    4. ...and many more.
    Please provide more information, so we can be able to provide some feedback to your issue.
    Shpat
  • 3.  RE: Guest SSID authentication error
    Posted Mar 04, 2021 12:55 PM
    Hi Ojha,
    Do you have a guest user connecting issue or authentication issue. Normally Guest SSID is open SSID.
    1. First guest user can connect to the network: AP/ Mobility controller responsible for every thins
    2. Obtain IP address: AP/Controller, DHCP Server
    3. Redirect to captive Portal: AP/MC, ClearPass
    4. Captive Portal authentication:
    Check where you are
    Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
    Network Engineer
    Plexus Global (Pvt) Ltd
    Colombo Sri Lanka
    +94717327420
