In a project I am using a MOXA media converter to go from copper to fiber optic and on the other end I have a H3C A5500 EI switch with an JD102B SFP transceiver. The MOXA IMC-21-S-SC fiber characteristics are 100 BASE FX. The HP web page says the JD102B is a 100 BASE FX SFP but the A5500 is reporting it as a 100 BASE SX SFP using the following command
<H3C>display transceiver interface gigabitethernet1/0/5
Are 100 BASE FX and 100 BASE SX incompatible then? Is the HP part number wrong?
Regards.
