Comware
  • 1.  H3C S5120-52C-PWR-EI Stack - problem after adding a member
    Posted Aug 11, 2013 11:32 AM
    I have a stack of three (3) H3C S5120 and just added one  H3C S5120 as a 4th member.
    Before adding the 4th member I did the following things:
    - updating the firmware of the new member to the same version as the stack members
    - renumbering of the new member number 4
    After restarting the stack I have my four members (display device), except that the command "dir slot4 # flash :/" displays the following error message " % Wrong device "slot4#flash:/" "
    Help please
  • 2.  RE: H3C S5120-52C-PWR-EI Stack - problem after adding a member
    Posted Aug 12, 2013 02:45 AM
    Same configuration - no problem.
    Please provide more information.
    disp version, disp irf, disp irf conf, disp irf topo
    br
    Manuel
  • 3.  RE: H3C S5120-52C-PWR-EI Stack - problem after adding a member
    Posted Aug 12, 2013 04:40 AM
    Hi Manuel,
    Thank you very much for your answer. Below are additional informations.
    But I have a question: why the 4th member (the last member added to the stack) becomes Master despite the fact that it has the lowest priority ?
    <A5120_PLC_3N_ASC>display version
    HP Comware Platform Software
    Comware Software, Version 5.20.99, Release 2220-US
    Copyright (c) 2010-2013 Hewlett-Packard Development Company, L.P.
    HP A5120-48G-PoE+ EI Switch with 2 Interface Slots uptime is 9 weeks, 3 days, 15 hours, 18 minutes
    HP A5120-48G-PoE+ EI Switch with 2 Interface Slots with 1 Processor
    128M bytes SDRAM
    16384K bytes Flash Memory
    Hardware Version is REV.B
    CPLD Version is 007
    Bootrom Version is 607
    [SubSlot 0] 48GE+4SFP+POE Plus Hardware Version is REV.B
    [SubSlot 1] 2 CX4 Hardware Version is REV.A
    <A5120_PLC_3N_ASC>display irf
    Switch Role Priority CPU-Mac Description
    1 Slave 32 3ce5-a6e2-ebb1 -----
    2 Slave 31 3ce5-a6aa-fc38 -----
    3 Slave 30 3822-d601-50fb -----
    *+4 Master 29 d07e-2838-c054 -----
    * indicates the device is the master.
    + indicates the device through which the user logs in.
    The Bridge MAC of the IRF is: 3ce5-a6e2-ebad
    Auto upgrade : yes
    Mac persistent : 6 min
    Domain ID : 0
    <A5120_PLC_3N_ASC>
    <A5120_PLC_3N_ASC>
    <A5120_PLC_3N_ASC>display irf conf
    <A5120_PLC_3N_ASC>display irf configuration
    MemberID NewID IRF-Port1 IRF-Port2
    1 1 Ten-GigabitEthernet1/1/1 Ten-GigabitEthernet1/1/2
    2 2 Ten-GigabitEthernet2/1/1 Ten-GigabitEthernet2/1/2
    3 3 Ten-GigabitEthernet3/1/1 Ten-GigabitEthernet3/1/2
    4 4 Ten-GigabitEthernet4/1/1 Ten-GigabitEthernet4/1/2
    <A5120_PLC_3N_ASC>
    <A5120_PLC_3N_ASC>
    <A5120_PLC_3N_ASC>display irf topo
    Topology Info
    IRF-Port1 IRF-Port2
    Switch Link neighbor Link neighbor Belong To
    4 UP 1 UP 3 d07e-2838-c054
    1 UP 2 UP 4 d07e-2838-c054
    2 UP 3 UP 1 d07e-2838-c054
    3 UP 4 UP 2 d07e-2838-c054
    <A5120_PLC_3N_ASC>
    Regards
    Ferdo
