We have 2XS5500-28C-EI v5.20, R2202 and IRFed as one switch.
our ACL task is that only 150.21/22 can be access to 192.168.10.49 for tcp 1433, and 150 range cannot acceess to other 192.168.10.0/24 resources. the current configs as the following. after this configs, we still can access 192.168.10.0/24 from 192.168.150.0/24. what's wrong with the configs regarding ACL?
also I checked with the manual, there is a "packet-filter" command to apply ACL under interface (looks like it is right command for applying ACL), but I cannot see this "packet-filter" under system-view level under interface, do I need to upgrade the IOS (firmware)?
Much appreciated for any advice. thanks
acl number 3050
rule 0 permit tcp source 192.168.150.21 0 destination 192.168.10.49 0 destination-port eq 1433
rule 5 permit tcp source 192.168.150.22 0 destination 192.168.10.49 0 destination-port eq 1433
rule 15 permit tcp source 192.168.150.0 0.0.0.255 source-port eq 3389
rule 20 deny ip source 192.168.150.0 0.0.0.255 destination 192.168.10.0 0.0.0.255
rule 25 deny ip source 192.168.150.0 0.0.0.255 destination 192.168.100.0 0.0.0.255
rule 100 permit ip
traffic classifier FirewallV150 operator and
if-match acl 3050
traffic behavior hehavior_FirewallV150
filter permit
qos policy policy_FirewallV150
classifier FirewallV150 behavior hehavior_FirewallV150
interface GigabitEthernet1/0/21
port access vlan 150
qos apply policy policy_FirewallV150 inbound
