Comware
  • 1.  H3C S5500-52C-PWR-SI firmware update problem
    Posted Oct 21, 2014 05:22 AM
    Hi guys,
            i would like to know on how to upgrade the current firmware of this switch to with new firmware
    A5500SI-CMW520- R2221P04.bin(13mb).
        as for compatibility of the new firmware, i've already asked HPtechub for series of documents which so far shows compatible.
          deletion of unnecessary files were already tried as well as resetting the recycle bin to free up space for the new firmware.
       another purpose of upgrade is to enable the new 10G module (JD368B); can't recognized by the switch
    <H3C-POE1-RPC>display version
    H3C Comware Platform Software
    Comware Software, Version 5.20, Release 1207
    Copyright (c) 2004-2007 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
    H3C S5500-52C-PWR-SI uptime is 1 week, 0 day, 22 hours, 42 minutes
    H3C S5500-52C-PWR-SI with 1 Processor
    128M bytes SDRAM
    16384K bytes Flash Memory
    Hardware Version is REV.B
    CPLD Version is 007
    Bootrom Version is 122
    [SubSlot 0] 48GE+4SFP+POE Hardware Version is REV.B
    <H3C-POE1-RPC>dir
    Directory of flash:/
       0     -rw-   7305305  Dec 05 2007 09:44:38   s5500si-cmw520-r1207.bin
       1     -rw-      3063  May 04 2000 10:45:59   startup.cfg
    15240 KB total (8096 KB free)
    <H3C-POE1-RPC>reset recycle-bin
    The recycle-bin is empty.
    <H3C-POE1-RPC>reset recycle-bin /fo
    <H3C-POE1-RPC>reset recycle-bin /force
    any help is greatly appreciated
    thanks in advance ,
    Harvey
    #5500
    #firmware
    #10G
    #upgrade
    #s5500
  • 2.  RE: H3C S5500-52C-PWR-SI firmware update problem
    Posted Nov 03, 2014 06:41 PM
    it looks that the flash cannot hold the old and the new image concurrently. So before loading the software you need to delete the old one.
    <H3C-POE1-RPC>delete /unreserved s5500si-cmw520-r1207.bin
    <H3C-POE1-RPC>ftp x.x.x.x
    [ftp] get A5500SI-CMW520- R2221P04.bin
    [ftp] bye
    <H3C-POE1-RPC>boatloader file A5500SI-CMW520- R2221P04.bin
    <H3C-POE1-RPC>save
    <H3C-POE1-RPC>reboot
  • 3.  RE: H3C S5500-52C-PWR-SI firmware update problem
    Posted Nov 03, 2014 07:44 PM
    Thanks for the response! :)
           do i have to boot the switch from extended BOOTROM? i heard that most of the H3C switches before have problems on firmware upgrades due to small size of flash. I it can detect the 10G SFP+ module upon upgrade.
  • 4.  RE: H3C S5500-52C-PWR-SI firmware update problem
    Posted Aug 19, 2016 08:16 AM
    an old post but it could be of a help for others
    Yes you want to boot the switch from extended bootrom and load your .bin from there, I come across the same problem on a HP3600
