Comware
  • 1.  H3C S5500 Si POE 48 - Front Mounting Brackets
    Posted Apr 04, 2016 10:29 AM
    Hi all,
    We have a few of these switches and need the front mounting brackets for them, but I cannot find this part number anywhere.
    Can anyone advise how to get these?
  • 2.  RE: H3C S5500 Si POE 48 - Front Mounting Brackets
    Posted Apr 04, 2016 11:32 AM
    They should have been in the box with the switch.  Usually they are cable tied to the serial cable.  I'm not sure that they are separately orderable.  You can check the HPE Parts Store to see what they have.
    Use the Parts Surfer to find the part number:  http://partsurfer.hpe.com/
    Then under the Services Tab, go to the HPE Parts Store.
    Good luck!
    David
  • 3.  RE: H3C S5500 Si POE 48 - Front Mounting Brackets
    Posted Apr 04, 2016 11:40 AM
    Thanks for reply, I have already been through the partssurfer store and they are not listed.
    We simply need to order 3 sets of new brackets and cannot find a way to order them or even source them from anywhere.
    If they are not seperatley orderable, what options are there?
