Handling onboarding/web logins with users who logged in with incorrect SAML/OAuth credentials
  • 1.  Handling onboarding/web logins with users who logged in with incorrect SAML/OAuth credentials
    Posted 4 days ago
    A few years ago, I looked at configuring our Bring Your Own Device (BYOD) Wi-Fi captive portal to utilize SAML authentication from Google since it would better align with how users authenticate elsewhere in our institution. I used the Onboard and Cloud Identity Providers document to successfully create an Aruba Guest Web Login example that could log users in with SAML authentication. After performing login tests through the Web Login, I discovered an issue where users could input personal Google credentials into the login prompt and receive a 403 app_not_configured_for_user message from Google. Once the 403 error is given to a device, getting an option from Google to log in with a different account is tough. Since BYOD equipment is logging into this captive portal, the chance that the user could mistakenly input their personal Google account into the SAML authentication is high.
    An example of an error 403 from Google logging in with the wrong credentials
    I've looked to see if there is a method of forcing users always to log in when they reach a SAML webpage but I haven't had much luck with any of the suggestions (StackOverflow examples 1 & 2). I have considered performing the OAuth implementation using the Cloud Identity option, but I believe the same issue exists.
    I am curious how others handle incorrect credentials being passed to SAML from a ClearPass web login. Right now, my current captive portal utilizes LDAPS through on-premises Active Directory as a workaround since it won't accept anything but institution credentials but I would like it to use a more modern cloud-based authentication method from Google or Microsoft Azure to use instead.
    Environment Details
    • Google Workspace for Education
    • Aruba ClearPass 6.11.9.259693
    • Aruba Central with WAPs running AOS-10
  • 2.  RE: Handling onboarding/web logins with users who logged in with incorrect SAML/OAuth credentials
    Posted 2 days ago
    This looks like a message from de Google IdP, which makes sense if someone uses a personal account instead of the Workspace account. That StackOverflow is more about people forcing to sign-in rather than doing a seamless automatic sign-on; it doesn't help if someone signs in with the wrong account.
    From the Google IdP perspective, I see why they are doing that and pointing back to your SP (which is wrongly configured in the Google personal account context). What you would be looking for is a way to instruct Google to ONLY accept logins for your Workspace, but unsure if that is possible. With Azure/Entra ID there are similar issues if someone logs in with an account from another organization, and don't think the message is much more descriptive.
    I think educating your users, put maybe additional information on your own sign-in page, or having the sign in error easily found in your knowledgebase/help pages is best achievable. But others may have found a more elegant solution?
