Hardware Mobility Conductor appliance License Capacity
  • 1.  Hardware Mobility Conductor appliance License Capacity
    Posted Jun 12, 2023 08:05 AM
    Hello;
    I have two hardware mobility conductors 1K in vrrp with 2 controllers 7240XM in cluster.
    The Mobility Conductor have already 1000 AP licenses,
    I need to add abaout 58 Access-points, there is possibility to enlarge the capacity of the hardware Mobility Conductor?
    Is the hardware mobility Conductor fixed or can be the possibility to add memory and CPU and upgrade the license to 5k?
    Or, If I add licenses directly to the Wireless controller It will be counted in  the total licenses in the mobility conductor?
    Dario Nardello
    ACMP ACSP ACCP ACEP
  • 2.  RE: Hardware Mobility Conductor appliance License Capacity
    Posted Jun 12, 2023 11:29 AM
    The hardware appliance has a fixed capacity, in your case this is 1K devices. As it is a closed appliance you cannot upgrade the memory or CPU. The licenses you purchase would still need to be applied to the Mobility Conductor and then consumed by the Managed Device. Further license info.
