  • 1.  Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 14, 2014 05:38 PM
    I am using CPPM 6.3.1 and want to create authentication for a printer, or any headless devices.
    First I create the device in Guest:
    In CPPM Authentication Sources only [Guest Device Repository] and [Guest User Repository] are used.
    Assign role TIPS-HEADLESS if SponsorName EXIST
    Enforcement to return the HEADLESS role to controller
    PROBLEM: the printer has never hit TIPS-HEADLESS role
    Thanks.
  • 2.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 14, 2014 05:41 PM
    You need to do the guest device repository on a RADIUS MAC authentication
    service. Do you have a MAC check service?
  • 3.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 14, 2014 05:52 PM
    Tim,
    Thanks for quick reply. Yes that is my problem. MAC AUTH added, and it works!!!!
  • 4.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 14, 2014 06:03 PM
    You should really separate out your MAC auth and web auth into separate
    services.
    You can use the service template "guest access with MAC caching" to do
    this.
  • 5.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 15, 2014 12:16 PM
    Tim,
    I am very approciated you advice.  If you don’t mind, I’d like to follow up with a question: I am using guest to connect and authorize wireless printer.  Can I move printer to different VLAN after it was authenticated?
    Best Regards,
  • 6.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 15, 2014 12:34 PM
    With a MAC auth, yes.
    There are two ways of doing this:
    1) Create a printer user-role on the controller and attach a VLAN to it.
    2) Return a VLAN ID or VLAN name with an enforcement profile in your enforcement policy.
  • 7.  RE: Headless Authenticaion in CPPM 6.3 Guest
    Posted Apr 15, 2014 02:31 PM
    Score again.  Thanks Tim.
    I use #2, return VLAN ID from CPPM.  First an atribute "Aruba-User-Vlan" must be added to server group at the controller, then add VLAN ID to Enforcement profile.  Works like a champ!!!
