  • 1.  Help? Aruba Instant IAP-105-US bandwidth limitations?
    Posted Jul 10, 2014 05:28 PM
    Is it possible on the Aruba Instant IAP-105-US to set bandwidth limitations ?
    In general ? for the system for each client ? and if so where ?
    Also ..
    I cannot remember were to set that clients can NOT see other computers on the same system.
    Where is the darn setting?
    THANKS !
  • 2.  RE: Help? Aruba Instant IAP-105-US bandwidth limitations?
  • 3.  RE: Help? Aruba Instant IAP-105-US bandwidth limitations?
    Posted Jul 10, 2014 05:46 PM
    WOW .. Thank you for the VERY quick reply!
    Thats great ! looks like this is what i was looking for !
  • 4.  RE: Help? Aruba Instant IAP-105-US bandwidth limitations?
    Posted Jul 10, 2014 06:12 PM
    Sorry .. what is the diffenece ?
    I do NOT want people on the same network .. OR
    directly connected to the same IAP OR are on the same Aruba Instant network?
    To see each other and or ping .. see files ect.
    What One should I use ?
    Deny Inter User Bridging and Deny Local Routing
     Deny Inter User Bridging— This feature allows you to deny traffic between two clients which are
    directly connected to the same IAP or are on the same Aruba Instant network.
     Deny Local Routing— This feature allows you to deny local routing traffic between clients which are
    To enable or disable these features, go to Settings > General in the Aruba Instant UI
  • 5.  RE: Help? Aruba Instant IAP-105-US bandwidth limitations?
    Posted Jul 10, 2014 06:21 PM
    First one
