Should I also disable the inter vlan routing? I went ahead and disabled the inter local routing.There is also the other option under 'Configuration -> system -> Show advanced options -> Deny inter user bridging'
I want my router/firewall to handle all VLAN traffic. There is an option to deny intra VLAN traffic. This is under 'Configuraiton -> Networks -> (network SSID) -> advanced options -> Deny intra vlan traffic'. Will this cause all destination intra vlan traffic to be sent to the default gateway?
Original Message:
Sent: Jan 25, 2025 11:17 AM
Subject: Help Managing DHCP Leases on Netgate Firewall with VLANs and APs
Your best bet for starting out is to ignore the wired port profiles. Under normal operation there is zero reason to mess with them, and in fact the default wired port profile will (when using default configuration) be mostly ignored when the port is acting as an uplink.
As mentioned, what you are looking for is "a separate configuration item under System called Uplink switch native VLAN".
Default behavior under IAP running some versions of AOS will bridge traffic between clients connected to the same IAP. See https://arubanetworking.hpe.com/techdocs/CLI-Bank/Content/instant/deny-local-rout.htm
Carson Hulcher, ACEX#110
Original Message:
Sent: Jan 25, 2025 11:04 AM
So, I solved the problem. It wasn't anything related to the APs or my misconfigured Native VLANs. I plan on fixing that this weekend, and thank you for pointing that out. It was duplicate DHCP processes running in the Netgate firewall. I raised a support ticket and they dialed into the modem and found some bad Kea DHCP processes running. Support terminated these and the leases started populating. 🤦🏻♂️. The LAGG is configured with LACP with Layer 2/3/4.
I didn't quite understand the purpose of the Native VLAN, but after some reading I feel I understand more. My uplink switch is currently using Native VLAN 888. I'm still a bit confused on the correct way to set my "Uplink switch native VLAN". I see that I can set a "native-vlan" within my default_wired_port_profile. Additionally, when I execute show uplink config
I can see Uplink wired-xx : DHCP
. There is a setting in Config -> Access points -> Uplink -> Uplink management VLAN. Is this related to that Uplink wired-xx or the "Uplink siwtch native vlan"?
Is the "Uplink switch native VLAN" just the "native-vlan" that is set in the default_wired_port_profile?
Also, how exactly do these default_wired_port_profiles
work? My main conductor AP only has the single Eth port so what are these other ports referring to with this profile?
I have another question about the AP rules. I currently have all of my APs SSIDs setup as "Client IP & VLAN Assignment" set to network assigned and client vlan assignment as static. I see my Wired Port Table is showing my ETH0 as WAN. Do the devices that are connected on the AP have to travel back to the firewall to be re-routed or is their any routing enabled at the AP level? I want to control all my intervlan routing from my firewall.
Wired Port Table------------------Port State Type Bonding(Admin/Oper/Active)---- ----- ---- --------------------------eth0 UP WAN Yes/Yes/Yeseth1 DOWN WAN Yes/Yes/Noeth2 DOWN WAN Yes/Yes/Noeth3 DOWN WAN Yes/Yes/Noeth4 DOWN WAN Yes/Yes/No
Original Message:
Sent: Jan 24, 2025 09:49 AM
The untagged VLAN on your AP uplink should be the VLAN used to manage the AP. If you are going to modify the wired port profile for the uplink, then make sure that the native VLAN matches what is on the switch. There is a separate configuration item under System called "Uplink switch native VLAN" that should also match the native VLAN on the switch port.
The duplicated DHCP packets, you captured that on an AP uplink or at the uplink to the firewall? Your LAG to the firewall, is that using LACP or did you configure statically?
Original Message:
Sent: Jan 23, 2025 11:49 PM
I setup the packet capture on my 24port switch from the 3 trunks that from my APs to the LAGG going to my firewall. It looks like all the IPs that are connected through the APs are generating duplicate DHCP requests traveling to my firewall. I did a packet capture on my firewall and it looks like it's dropping that additional request and everything is correct.
Regarding my configuration.... I really cobbled it together.
I have the wired-SetMeUp access rules that can't seem to be changed and then a default_wired_port_profile that I set to allow all on each port. All three access points are fed individual by single trunk ports off my Cisco switch and I'm not sure if i have something misconfigured there. Should the uplink be using my untagged VLAN?
With show ip route
I can only see two routes configured. One to my vlan 27 and the management interface i configured. Then the other goes to that magic vlan. All of my wired connections to the APs are configured as trunks that carry all 4 vlans that I have individual SSIDs for and then the 1 that is for management vlan 27. Is the issue that they are all being carried through the uplink under that single vlan? There should be 1 route per vlan?
I've included the following commands below,show ip route
, show uplink status
, show wired-port-settings
,show uplink config
,show ip interface brief
aruba-ap# show ip routedefault via 192.168.27.1 dev br0192.168.27.0/24 dev br0 src 192.168.27.20172.31.98.0/23 dev br0.3333 src 172.31.98.1aruba-ap#
Is my Management VLAN acting like my WAN on my AP?
aruba-ap# show uplink statusUplink preemption :disableUplink preemption interval:600Uplink enforce :eth0Uplink wired-27 :DHCPInternet failover :disableInternet failover IP :x.x.x.xMax allowed test packet loss:10Secs between test packets :30VPN failover timeout (secs):0Internet check timeout (secs):10APIX type :NONECertification type :NONEValidate server :NONEUplink Table------------Type VLAN State Reach State Prio In Use Interface IP Mask GW Sent Lost Cont lostEthernet 27 UP UP 0 Yes br0 192.168.27.20 255.255.255.0 192.168.27.1 0 0 0Cellular - INIT INIT 7 No ppp0 0.0.0.0 0.0.0.0 0.0.0.0 0 0 0Wifi-sta - INIT INIT 6 No wuplink0 0.0.0.0 0.0.0.0 0.0.0.0 0 0 0Wired Port Table----------------Port State Type Bonding(Admin/Oper/Active)bond0 UP WAN No/No/Yesaruba-ap#
aruba-ap# show wired-port-settingsWired Port Profiles-------------------Name VLAN Mode Allowed VLANs Native VLAN Admin Status Role Speed Duplex POE In Use Authentication Method STP Trusted---- --------- ------------- ----------- ------------ ---- ----- ------ --- ------ --------------------- --- -------wired-SetMeUp Access all guest Up wired-SetMeUp auto auto No Yes None No Nodefault_wired_port_profile Trunk all 888 Up default_wired_port_profile auto full No Yes None No YesPort Profile Assignments------------------------Port Profile Name---- ------------0 default_wired_port_profile1 default_wired_port_profile2 default_wired_port_profile3 default_wired_port_profile4 default_wired_port_profileUSB wired-SetMeUparuba-ap#
aruba-ap# show uplink configUplink preemption :disableUplink preemption interval :600Uplink enforce :eth0Uplink wired-27 :DHCPInternet failover :disableInternet failover IP :172.64.x.1Max allowed test packet loss :10Secs between test packets :30VPN failover timeout (secs) :0Internet check timeout (secs) :10aruba-ap#
aruba-ap-505-tvcabinet# show ip interface briefInterface IP Address / IP Netmask Admin Protocolbr0 192.168.27.20 / 255.255.255.0 up upbr0.3333 172.31.98.1 / 255.255.254.0 up uparuba-ap-505-tvcabinet#
Original Message:
Sent: Jan 21, 2025 05:56 PM
OK, so from your questions:
- If you've not configured something else on the network to provide DHCP, then nothing else should be managing DHCP unless you've got a rogue DHCP server active.
- No, Instant or Controller based should have no impact on the DHCP behavior when managing from the network.
- No, and remote AP isn't an option unless you have a controller for the AP to be managed by and build the VPN back to.
- Easiest is to not configure IP interfaces on the client facing VLANs.
Run a packet capture between the firewall and switch, see if the entire DHCP exchange is being received/sent at that side.
Original Message:
Sent: Jan 21, 2025 05:27 PM
I can see all the missing IP addresses in the Dashboard -> Clients on the AP. I can also see the IPs in the ARP table on my firewall, but I cannot see the DHCP leases within the DHCP server on my firewall. I'm still getting that error on my firewall that their is another DHCP server active and it cannot bind. I mentioned that in my original post.
Original Message:
Sent: Jan 21, 2025 05:00 PM
assuming they're managed there because they're showing up in the list of clients
Can you please be a little more specific about what you mean here? On the firewall? On the AP?
Devices connected to the IAPs should always show up in the client list on the IAP once they have an IP address assigned.
Original Message:
Sent: Jan 21, 2025 04:54 PM
Everything is set as network managed. The DHCP server IP on the client is the gateway that is on the interface on the firewall. I'm sorry I am new to networking so trying my best here. I'm assuming they're managed there because they're showing up in the list of clients.
Original Message:
Sent: Jan 21, 2025 04:44 PM
The magic VLAN is what gets used when using "Virtual Controller managed" for client IP assignment, thus my comment about all WLANs being set to "Network assigned".
How do you know the devices are being managed by an AP? What server IP is being reported for the DHCP information on the client?
Original Message:
Sent: Jan 21, 2025 04:35 PM
Thank you for your response! I want to clarify a few points:
I am not using VLAN 1 as the native VLAN in my network. That was just an example to simplify my explanation.
The DHCP server on my Netgate firewall is assigning IP addresses correctly to devices on VLANs 2–5. However, the leases are not consistently registering with the firewall. For example, a new device showed up in the lease table yesterday; however, most have not. Initially, the firewall was registering leases properly, allowing me to set static mappings. These static mappings still persist after lease expiration, even though the devices are now being managed by the AP instead of the firewall.
I ran show dhcp-allocation
, and here is the output for dnsmasq.conf
-------------------- /etc/dnsmasq.conf --------------------
listen-address=127.0.0.1
addn-hosts=/etc/ld_eth_hosts
addn-hosts=/etc/ld_ppp_hosts
dhcp-src=172.31.98.1
dhcp-leasefile=/tmp/dnsmasq.leases
dhcp-authoritative
aruba-raw-socket-mode
#magic-vlan
vlan-id=3333
dhcp-range=172.31.98.3,172.31.99.254,255.255.254.0,12h
dhcp-option=1,255.255.254.0
dhcp-option=3,172.31.98.1
dhcp-option=6,10.0.17.1
dhcp-option=15,edge.exampledomain.com
-------------------- /tmp/dnsmasq.leases --------------------
role:1 ipaddr#127.0.0.1
-------------------- dhcp relay conf --------------------
Could any of these configurations be contributing to the issue? I don't see any options in the GUI to adjust these parameters.
Thanks again for your help!
Original Message:
Sent: Jan 21, 2025 11:32 AM
First and foremost, don't use VLAN 1 for production.
As long as the WLANs are all configured for network assigned addressing and no DHCP is configured on the APs, all DHCP should be coming from the network which should mean the firewall, maybe a switch, or a server on the network. If you don't have helper addresses configured, then the only option is those devices that have an IP address in the network.
Original Message:
Sent: Jan 18, 2025 10:51 PM
Below is an overall diagram of my network setup. I'm having trouble managing all devices through the DHCP server on my Netgate firewall. The firewall gives an error stating that "a server is already listening on the expected port," but I have disabled all DHCP servers/relays in the GUI settings on my switches and access points (APs).
My network has VLANs 1–8:
- VLAN 1 is the native VLAN configured on my switches and also on the APs.
- VLANs 2, 3, 4, and 5 each have separate SSIDs mapped to them.
The DHCP server on the Netgate firewall is partially working because devices connecting to the SSIDs on VLANs 2–5 receive the correct IP addresses from the pools configured on the firewall. However, the firewall doesn't seem to "own" or recognize the DHCP leases, which prevents me from setting up static mappings.
My questions are:
- What could be causing the firewall to not manage all DHCP leases?
- Does this issue stem from operating the network without a controller?
- Would converting the APs into Remote APs solve this, or is there a better approach?
- What is the best way to configure my switches so they act as Layer 2 devices, and ensure that my Netgate firewall handles all DHCP leases?
Thanks in advance for your help!
