Help only getting 300 mbs Ap115
cjoseph
cjosephMay 15, 2017 07:49 PM
  • 1.  Help only getting 300 mbs Ap115
    Posted May 15, 2017 07:39 PM
    Hello I have 2 ap 115 setup on vertual controler and when im next to the ap's the max speed I get is 300mbs. I have the 80hz support enabled. But im sure im missing somthing. Can some one point me to what need to be done so I do get speed faster then 300mps?
  • 2.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 07:49 PM
    Does your client support 80mhz channels?
  • 3.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 07:58 PM
    Yes they do. I had dfrent ap's before setup for wide ch before and they where getting 1200.
    By they way here is my config. Mybe I should change somthing? I only have like 10 clients on this 2 ap's i many wanted it for fast roming.
    version 6.4.4.0-4.2.4
    virtual-controller-country US
    virtual-controller-key f7e8927f188f994780da45a0b858a16ae9
    name ArubaDown
    virtual-controller-ip 192.168.1.8
    terminal-access
    telnet-server
    led-off
    clock timezone Eastern-Time -05 00
    rf-band all
    allowed-ap 18:64:72:cb:e4:77
    allowed-ap 18:64:72:cb:e2:84
    arm
     wide-bands all
     80mhz-support
     min-tx-power 18
     max-tx-power 127
     band-steering-mode prefer-5ghz
     air-time-fairness-mode fair-access
     client-aware
     scanning
     client-match
    rf dot11g-radio-profile
     spectrum-monitor
     dot11h
    rf dot11a-radio-profile
     spectrum-monitor
     dot11h
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    extended-ssid
    mgmt-user User123 3382fc9c860a8861dfa9127075e8ab02f
    wlan access-rule default_wired_port_profile
     index 0
     rule any any match any any any permit
    wlan access-rule wired-instant
     index 1
     rule masterip 0.0.0.0 match tcp 80 80 permit
     rule masterip 0.0.0.0 match tcp 4343 4343 permit
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
    wlan access-rule AlexN5G
     index 3
    wlan ssid-profile AlexN5G
     enable
     index 1
     type employee
     essid AlexN5G
     wpa-passphrase da2fe9e9721dbfdbc67a6
     opmode wpa2-psk-aes
     max-authentication-failures 0
     rf-band all
     captive-portal disable
     dtim-period 1
     broadcast-filter arp
     g-min-tx-rate 12
     a-min-tx-rate 18
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 64
     dot11r
     dot11k
     dot11v
     strict-svp
    auth-survivability cache-time-out 24
    url-visibility
    wlan external-captive-portal
     server localhost
     port 80
     url "/"
     auth-text "Authenticated"
     auto-whitelist-disable
     https
    blacklist-time 3600
    auth-failure-blacklist-time 3600
    ids
     wireless-containment none
     infrastructure-detection-level high
     client-detection-level high
     infrastructure-protection-level high
     client-protection-level high
    wired-port-profile wired-instant
     switchport-mode access
     allowed-vlan all
     native-vlan guest
     no shutdown
     access-rule-name wired-instant
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 1
     shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    enet0-port-profile default_wired_port_profile
    uplink
     preemption
     enforce none
     failover-internet-pkt-lost-cnt 10
     failover-internet-pkt-send-freq 30
     failover-vpn-timeout 180
    airgroup
     enable
    airgroupservice airplay
     enable
     description AirPlay
    airgroupservice airprint
     enable
     description AirPrint
    airgroupservice itunes
     enable
    airgroupservice remotemgmt
     enable
    airgroupservice sharing
     enable
    airgroupservice chat
     enable
    airgroupservice AmazonTV
     enable
    airgroupservice DIAL
     enable
    airgroupservice "DLNA Media"
     enable
    airgroupservice "DLNA Print"
     enable
    airgroupservice allowall
     enable
  • 4.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:12 PM
    Tryed posting my config but its not comng up.
    Yes the laptop im trying to get over 300mbs dose support more i had it on 1200 with a defrent ap.
  • 5.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:16 PM
    name ArubaDown
    terminal-access
    telnet-server
    led-off
    rf-band all
    allowed-ap 18:64:72:c2:e1:70
    allowed-ap 18:64:72:c5:02:84
    arm
     wide-bands all
     80mhz-support
     min-tx-power 18
     max-tx-power 127
     client-aware
     scanning
     client-match
     spectrum-monitor
     dot11h
     spectrum-monitor
     dot11h
    extended-ssid
     index 0
     index 1
     index 3
     enable
     index 1
     type employee
     essid AlexN5G
     opmode wpa2-psk-aes
     rf-band all
     dtim-period 1
     g-min-tx-rate 12
     a-min-tx-rate 18
     dot11r
     dot11k
     dot11v
     strict-svp
    url-visibility
     server localhost
     port 80
     url "/"
     https
    blacklist-time 3600
    ids
     allowed-vlan all
     native-vlan guest
     no shutdown
     speed auto
     duplex auto
     no poe
     type guest
     no dot1x
     allowed-vlan all
     native-vlan 1
     shutdown
     speed auto
     duplex full
     no poe
     type employee
     no dot1x
    uplink
     preemption
     enforce none
    airgroup
     enable
     enable
     description AirPlay
     enable
     enable
     enable
     enable
     enable
     enable
     enable
     enable
     enable
     enable
  • 6.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:22 PM
    It is possible that your laptop is connecting on the 2.4ghz band.
  • 7.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:27 PM
    on the 2.4 the max would be 150mbs no?
  • 8.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:32 PM
    Im using my phone now to test its a samsung galaxy s6 edge and im using wifi analyzer it says im connected to ch60(62) 40mhz 270mbps
  • 9.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:46 PM
    Im thnking it has to do somthing with the adaptive radio managment assigned seting in a ap radio seting as i have all the 5ghz ch avalable in the rf seting under valid chanels. But if i wanted to how would i force 80hz ch?
  • 10.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:47 PM
    If your access points have an "E" after the channel, that means they are 80mhz channels.
  • 11.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 10:09 PM
    OK i set it up to wide ch the ones with E at the end and I only get 40hz. Can there be somthing I enabled thats not seting up 80hz?
  • 12.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 10:14 PM
    Here is my RF seting.
  • 13.  RE: Help only getting 300 mbs Ap115
    Posted May 16, 2017 05:13 AM
    You should type "show ap association" on the commandline to see what capabilities the client has negotiated with the Instant AP.
  • 14.  RE: Help only getting 300 mbs Ap115
    Posted May 16, 2017 06:25 AM
    Hi!
    AP115 is a 3x3:3 802.11n AP and can only do 40mhz channels as highest. I´d say your client is probably a 2x2 client and that´s why you´re not getting full speed from your 3x3 AP on that client.
    Cheers,
  • 15.  RE: Help only getting 300 mbs Ap115
    Posted May 16, 2017 12:25 PM
    Thank You that explanes it. What is the 80hz option that i have in the pickture for RF seting?
  • 16.  RE: Help only getting 300 mbs Ap115
    Posted May 16, 2017 01:00 PM
    That is for access points that support it.  Other devices will ignore that setting if they don't have support.
  • 17.  RE: Help only getting 300 mbs Ap115
    Posted May 15, 2017 08:43 PM
    No.  I would try with a laptop that supports 80mhz channels.
