Developer
  • 1.  HELP !! Simple dual ISP failover ... Can anyone 'tweak / edit' an existing NAE Script for CX6200 / CX6300?
    Posted Jun 11, 2025 09:33 AM
    Edited by killorp Jun 11, 2025 09:37 AM
    Existing NAE Script for ISP Failover solution won't load on CX6200/CX6300. 'connectivity_monitor'
    Has anyone managed to replicate / re-write the 'connectivity_monitor' NAE script so it can run on an Aruba CX6200/CX6300 ?
    The IP-SLA / NQA solution would be perfect but the NAE script 'connectivity_monitor' does load onto the CX6200 or CX6300 :(
    Background:
    See diagram attached
    I have a school on 2 sites (Upper + Lower) each with their own Core switch and each with their own Smoothwall and their own ISP circuit. There is even dual 10Gb Fibre between each site so it was basically a single site but the ISP circuits are split so each site has its own ISP circuit.
    Dual Core, dual Smoothwall, dual ISP and each would like to failover to the other if either ISP failed.
    (Upper CX6300 and Lower is CX6200)
    Using IP-SLA with Track'd default ip route would be ideal but .... as we all know .... you can't do IP route 'track' with Aruba CX and the CX6200 / CX6300 won't load up the NAE script 'connectivity_minotor'. !!
    Ticket logged with Aurba support but basically RTM but I am pulling my hair out .... I'm sure its simple.
    Any help / suggestions / words of comfort greatly appreciated :)
    Cheers
    Peter
    Attachment(s)
    pdf
    PK WAN connx v6 safe.pdf   143 KB 1 version
  • 2.  RE: HELP !! Simple dual ISP failover ... Can anyone 'tweak / edit' an existing NAE Script for CX6200 / CX6300?
    Posted 27 days ago
    Hi Peter,
    What error do you have ?
    Do you have check if there is the support of IP SLA on 6200F / 6300 ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: HELP !! Simple dual ISP failover ... Can anyone 'tweak / edit' an existing NAE Script for CX6200 / CX6300?
    Posted 27 days ago
    Hi yes. IP-SLA definitely works on CX6200 - it is running now.
    I assume it will work on CX6300 also.
    Sent from my iPhone
    The email you received and any files transmitted with it are confidential, may be covered by legal and/or professional privilege and are intended solely for the use of the individual or entity to whom they are addressed. If you have received this in error, please notify us immediately. If you are not the intended recipient of the email or the person responsible for delivering it to them, you may not copy it, forward it or otherwise use it for any purpose or disclose its contents to any other person. To do so may be unlawful. Any views or opinions presented in this email are solely those of the author and do not necessarily represent those of Nexus Associates (ICT) Ltd. Nexus Associates (ICT) Ltd. is not responsible for any changes made to the message after it has been sent.
  • 4.  RE: HELP !! Simple dual ISP failover ... Can anyone 'tweak / edit' an existing NAE Script for CX6200 / CX6300?
    Posted 11 days ago
    I also need this solution for CX6200. Could anyone edit the script "connectivity_monitor" for cx6200.
    Thanks!
    Nart.
  • 5.  RE: HELP !! Simple dual ISP failover ... Can anyone 'tweak / edit' an existing NAE Script for CX6200 / CX6300?
    Posted 11 days ago
    It's me again (from the other thread)
    I have an open ticket with Aruba/HPE Tech support and they investigating this issue.
    They advised that they tried to test the script on an 83xx switch but could not even get it to load so ....
    I'm keeping my fingers crossed they might yet come up with a solution ... or something :)
