Hi.
I'm trying to set up 3 IAP015. One is on our network, and the two others are supposed to connect to our network from the neighbouring building. First, I set up AP1 and configured the WLANS. Second, I connected AP2 and AP3 to the same network and they both got the configuration from AP2. Then I moved AP2 to the neighbouring building. It connected to AP1 without any problems. Last, I connected AP3 to a location in the neighbouring building which didn't get any signal from AP1. Both AP2 and AP3 are connected to the same switch, but AP3 does not connect to AP2. Am i missing some bridging configuration or something? Attached is a simple sketch of the topology.
Cheers
