Comware
Help with VLAN / Trunking HP 2810
  • 1.  Help with VLAN / Trunking HP 2810
    Posted Mar 24, 2009 06:27 AM
    I have two sites connected by a fibre link with an HP 2810 on each end. Right now there's only one VLAN being used (the default VLAN), but I need to link 3 VLANs from one switch to another.
    I have no problem creating the VLANs, my only problem is setting up the trunk that connects the two switches, mainly because I have only one port to do it (the one that's connected to the fibre channel converter).
    How can I create this trunk with only one port (24) and use it to transport the 3 VLANs?
    Please check the attached map for more information.
    Thank you very much!
  • 2.  RE: Help with VLAN / Trunking HP 2810
    Posted Mar 24, 2009 06:42 AM
    hi,
    here you go:
    conf t
    vlan 100
    untagged 24
    exit
    vlan 200
    tagged 24
    exit
    vlan 300
    tagged 24
    exit
    wr mem
    hth
    alex
  • 3.  RE: Help with VLAN / Trunking HP 2810
    Posted Mar 24, 2009 07:02 AM
    There's no need for trunking???
  • 4.  RE: Help with VLAN / Trunking HP 2810
    Posted Mar 24, 2009 07:27 AM
    a cisco trunk is tagging/untagging in the hp world.
    a hp trunk is link aggregation for more bandwith.
    hth
    alex
  • 5.  RE: Help with VLAN / Trunking HP 2810
    Posted Mar 24, 2009 08:12 AM
    Thanks!
