I was doing some research in my Lab the other day and I've noticed that my Instant 105 appears to be broadcasting a hidden SSID using
wpa-psk-tkip ? Has anyone else seen this? I have 0 configuration relating to this and I can see this being broadcast from other controllers. Here's what I've pulled from the logs from both the Instant and the 620 controller.
Here is the SSID in question
iwconfig output for aruba000
aruba000 IEEE 802.11na ESSID:"b73375eab4fa00c6290c67c905e2606"
Mode:Master Frequency:5.54 GHz Access Point: x:xx:xx:xx:xx:xx
Encryption key:EB22-7C1F-C903-DF36-C113-B162-087C-151D [2] Security mode:restricted
I can see it being advertised when checking ARM neighbours on a nearby controller
AP Tree
Monitor Eth MAC Radio BSSID ESSID RSSI Dur Cnt Class Clients AP-name Encryp IBSS
d8:c7:c8:ce:c3:0c 1 x:xx:xx:xx:xx:xx b73375eab4fa00c6290c67c905e2606 65 178 36 valid 0 wpa-psk-tkip no
The ap bss-table on the Instant does not show it broadcasting
Instant-105# show ap bss-table
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t
x:xx:xx:xx:xx:xx weebox ?/? 192.168.1.7 g-HT ap 6/19/19 2 Instant-105 0 2d:2h:56m:51s
x:xx:xx:xx:xx:xx weebox ?/? 192.168.1.7 a-HT ap 108+/24/24 2 Instant-105 0 2d:2h:56m:52s
x:xx:xx:xx:xx:xx weexbox ?/? 192.168.1.7 a-HT ap 108+/24/24 0 Instant-105 0 2d:2h:56m:44s
Any ideas what this hidden SSID is?
