High Availibility HA with 2 standalone controller
  • 1.  High Availibility HA with 2 standalone controller
    Posted Aug 11, 2017 06:31 AM
    Hello everyone,
    I'm new here and i hope everyone is doing well.
    I'm not new with the Aruba controller and I have an issue with the HA model.
    First, we want to try the Active/Active model with Master/redundancy. Apparantly, with the new version, the standby tunnel GRE is "acive" with the master-standby controller even-if i can't terminate GRE tunnel.
    We don't manage to create this model. So, Aruba tell us that the new model is standalone/standalone with an AirWave to work with.
    So, we read the VRD and we chosse :
    - Standalone/Standalone
    - controller ip loopback
    - VRRP with two controller
    - License Redundancy
    - Same configuration on both controller
    - HAGroup with the dual option (on standby IP adress)
    - LMS with the loopback address of the primary
    - DHCP server on the primary (even if we choose the static option for our AP-207)
    We don't see the standby tunnel on the second controller and when we shutdown the controller 1, Access Point can't access to the secondary.
    At this point, I don't know what to do.
    Have you a suggestion ?
    Attachment(s)
    txt
    default.txt   28 KB 1 version
    txt
    default-2.txt   27 KB 1 version
  • 2.  RE: High Availibility HA with 2 standalone controller
    Posted Nov 19, 2019 05:53 AM
    Do you find the answer? I have the same goal.
