Comware
  • 1.  high cpu usage
    Posted Sep 11, 2013 05:22 AM
    Hello guys.
    We have a stack with 8 3com 5500-EI, its all ok but one unit, unit 6, have high cpu usage all time....
    Look this:
    Unit 6
    Board 0 CPU busy status:
        88% in last 5 seconds
        92% in last 1 minute
        90% in last 5 minutes
    The question is, how i can look what is using it ?
    With cisco, IOS, have a command for look all process(sh process), but with 3com ?
    All other switches of stack are normal(50-60% cpu usage)...
    P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to Comware-Based.
    -HP Forum Moderator
  • 2.  RE: high cpu usage
    Posted Jan 04, 2014 06:08 PM
    I couldnt locate anything regarding this in the HP_CLI_Ref_Guide_ver2_JAN13.pdf file.
    I think you might be have better luck using the _hidecmd command.
    That is login to your device and run:
    system-view
    _hidecmd
    WARNING! only use the "display" command after you issued the _hidecmd (otherwise dragons and stuff will come and eat your switch alive ;-)
    That is "display ?"
    Use "quit" to get back to normal mode.
