  • 1.  How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 01:00 AM
    I have wireless set up using Virtual controller created by AP 505 consists 24 APs ( all are 505 model) , Can I add APIN0225 model to the virtual controller what I have.
    Appreciate your assistance
  • 2.  RE: How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 03:19 AM
    yes you can. You have to use a common supported Software Release.
    8.6.x code train will be supported by both AP types.
    Be sure to bring the Software version on the existing Cluster and on AP 225 seperate - before trying to join the cluster. If you have AirWave or Aruba Central as management Platform you don´t need that step. With AirWave you only have to bring that release to the Software Repository. With Central everything works automatically.
    Here are Installation Guidelines - https://www.arubanetworks.com/techdocs/Instant_8.x_RN_WebHelp/Content/8.6/upgrade-an-iap.htm
    But be aware that 8.6.x Code Train will get Out of Support by 1st of August 2024
  • 3.  RE: How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 04:39 AM
    Thanks for the reply
    here is my software version 8.7.1.3_79817 (Digitally Signed - Production Build)
    Is there any possibility to do the same with this version
  • 4.  RE: How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 05:57 AM
    Sorry no...because AP-225 is only Supported Up to Software Version 8.6.x
  • 5.  RE: How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 09:24 AM
    Please check the actual product number on the sticker on the back. APIN0225 is the regulatory type number. The product number can be AP-225 or IAP-225-RW/US/JP.
    If the product is an IAP model, you could create a cluster as mentioned in other posts.
    If the product is an AP-225, you need a mobility controller to operate (not another Instant AP).
  • 6.  RE: How Can I add APIN0225 to Virtual Controller made by AP-505
    Posted Nov 06, 2023 11:55 PM
    Hi Herman
    It's IAP-225-RW.
