Comware
  • 1.  How can I reset default factory setting for Aruba 6300 Poe Switch?
    Posted Aug 24, 2023 11:17 AM
    Hello All,
    I would like to know how to reset default factory setting for Aruba 6300 poe switch. I can only found the reset button and I forgot the username and password. So, how can i reset Aruba 6300 PoE switch? Please give me solutions. Note-Reset button only work device restart and not clear configuration.
  • 2.  RE: How can I reset default factory setting for Aruba 6300 Poe Switch?
    Posted Aug 25, 2023 03:03 AM
    Hi, does this procedure work on your device?
    https://www.arubanetworks.com/techdocs/AOS-CX/10.09/HTML/security_8360/Content/Chp_Mng_Use/res-swi-adm-pas-usi-ser-os-con-10.htm
  • 3.  RE: How can I reset default factory setting for Aruba 6300 Poe Switch?
    Posted Sep 21, 2023 11:01 AM
    To reset an Aruba 6300 PoE switch to its factory default settings, first power off the switch and locate the reset button, typically on the front panel. Press and hold the reset button, then power on the switch and continue holding for about 10-15 seconds before releasing it. This initiates a physical reset.
    Now, connect a computer to one of the switch's Ethernet ports, access the switch's web interface using the default IP address (commonly 192.168.1.1 or 192.168.0.1), and log in with the default username and password (admin/admin). Within the web interface, find the option to reset the configuration to factory defaults, confirm the reset, and then reconfigure the switch with your desired settings, including setting a new username and password. Hope it works!!
