Ok thanks,
As the report said client match has the follow input parameters:
- Sticky client check SNR (dB)
- SNR threshold (dB)
- Sticky Min Signal
I would like to know how can i managed these parametres in my virtual controller, because I can only manage in my IAP "CM threshold" and "CM neighbor matching %"
I supose the "CM threshold" is the same that SNR threshold but, I didn't understand what does "CM neighbor matching" mean?
Can you explain the realtion between these parameter ("CM neighbor matching") to "Stick client check SNR"? Are we talking about the same?
thanks
These is the report that I talking about:
https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/Client-Match-configuration-related-to-Sticky-Clients-AOS-6-3-and-above
