Hi Pavan,
Thank for your response currently, the reports tab don't work correctly
But is not exactly what I want, I would like to generate a heatmap directly with my mobile application using the meridian SDK for iOS and on the generated heatmap I would like only records movement of the current user.
How I can use the meridian SDK to do this? If it is not possible directly what are alternatives?
Thanks in advance
