Cloud Managed Networks
  • 1.  How to change gateway model in a Group?
    Posted Feb 19, 2021 07:12 AM
    Say I have 9400-LTE as a lab device and I build production configuration for a Group (named for example as LAB) in which my lab gw belongs to. Once configuration has been verified I create a production Group (name for example as PROD) by cloning the lab group, and introducing new name for the Group (PROD). All good so far, but in production I have 9400 devices (without LTE) and now in my PROD Group I see reference to model 9400-LTE... Is there a way to change the gw hw model of the group? For this very case I am not using LTE so I don't mind if I lose all the LTE-related settings. I am aware of the difference in physical LAN interfaces among the gateways, but in this very case also the LAN interfaces are the same... I really don't fancy the idea of using Central UI to configure this new group from scratch: all policies, network aliases, DPS settings, routing settings, radius servers etc...
    gone fishing.
  • 2.  RE: How to change gateway model in a Group?
    Posted Feb 20, 2021 06:54 PM
    you can add 9004 gateways to the group that had 9004-LTE.
    no issues with the config.
  • 3.  RE: How to change gateway model in a Group?
    Posted Feb 22, 2021 01:18 AM
    Thank you, ariyap!
    gone fishing.
  • 4.  RE: How to change gateway model in a Group?
    Posted Feb 24, 2021 11:52 AM
    Edited by Greg_W Feb 25, 2021 12:48 PM
    to assign gateways to a group, complete the following steps: In the Network Operations app, set the filter to Global. Under Maintain, click Organization > Groups. Under Manage Groups, from the devices table on the right, select the gateway that you want to assign to a new group.
    ACES ETM
    Springs Springs
