  • 1.  How to Configure 802.1X with AD Authentication and Per-User Device Limits in Aruba CPPM?
    Posted 6 days ago
    I want to configure 802.1X in Aruba CPPM with authentication through Active Directory, and I also want to limit each user to connecting only two devices. However, I haven't been able to get this feature working. What is the best way to achieve this?
    Request Details Summary -
    Session Identifier: R00000021-01-68483b67
    Date and Time: Jun 10, 2025 22:04:23 CST
    Username: shen
    End-Host Identifier:
    Access Device IP/Port:
    Access Device Name: 172.16.11.10
    Audit Posture Status: UNKNOWN (100)
    System Posture Status: UNKNOWN (100)
    Login Status: ACCEPT
    Policies Used -
    Service: 802.1x 802.1X Wireless
    Authentication Method: EAP-PEAP
    Authentication Source: AD:
    Authorization Source: [Guest User Repository], [Guest Device Repository], [Insight Repository], kk.com
    Roles: [User Authenticated]
    Enforcement Profiles: [Update Endpoint Known], _Guest Auth MAC Caching MAC Caching Session Limit, kk-test Guest MAC Caching, kk-802.1x 802.1X Wireless Profile1, [Allow Access Profile]
    Service Monitor Mode: Disabled
    Input RADIUS Attributes -
    Radius:Aruba:Aruba-AP-Group = OA
    Radius:Aruba:Aruba-Essid-Name = LAB
    Radius:Aruba:Aruba-Location-Id = 505
    Radius:IETF:Called-Station-Id =
    Radius:IETF:Calling-Station-Id =
    Radius:IETF:Framed-MTU = 1100
    Radius:IETF:NAS-Identifier = 172.16.11.10
    Radius:IETF:NAS-IP-Address = 172.16.11.10
    Radius:IETF:NAS-Port = 0
    Radius:IETF:NAS-Port-Type = 19
    Radius:IETF:Service-Type = 2
    Radius:IETF:User-Name = shen
    Input Computed Attributes -
    Authentication:ErrorCode = 0
    Authentication:Full-Username = shen
    Authentication:MacAuth = NotApplicable
    Authentication:NetBIOS-Name = kk
    Authentication:OuterMethod = EAP-PEAP
    Authentication:Posture = Unknown
    Authentication:Source = kk.com
    Authentication:Status = User
    Authentication:Username = shen
    Authorization:Sources = [Guest User Repository], [Guest Device Repository], [Insight Repository], kk.com
    Connection:AP-Name = kk_OA-505
    Connection:Client-Mac-Address =
    Connection:Client-Mac-Address-Colon =
    Connection:Client-Mac-Address-Dot =
    Connection:Client-Mac-Address-Hyphen =
    Connection:Client-Mac-Address-NoDelim =
    Connection:Client-Mac-Address-Upper-Hyphen =
    Connection:Client-Mac-Vendor = TP-Link Corporation Limited
    Connection:Dest-IP-Address = 172.16.11.200
    Connection:Dest-Port = 1812
    Connection:NAD-IP-Address = 172.16.11.10
    Connection:Protocol = RADIUS
    Connection:Src-IP-Address = 172.16.11.10
    Connection:Src-Port = 37351
    Connection:SSID = LAB
    Date:Date-Time = 2025-06-10 22:04:23
    Endpoint:Guest Role ID = %{GuestUser:Role ID}
    Endpoint:MAC-Auth Expiry = %{Authorization:[Guest User Repository]:ExpireTime}
    Endpoint:Username = shen
    Input Authorization Attributes -
    Authorization:kk.com:Account Expires = 9223372036854775807 [30828-09-14 10:48:05 CST]
    Authorization:kk.com:groupName = Administrators, Remote Desktop Users
    Output RADIUS Attributes -
    Post-Auth-Check:Action = Disconnect and Block Access
    Radius:Aruba:Aruba-User-Role = all
    Session-Check:Active-Session-Count = %{GuestUser:simultaneous_use}
    Status-Update:Endpoint = Known
    Alerts -
    Error Code: 0
    Error Category: Success
    Error Message: Success
    Alerts for this Request -
    Policy server: Failed to get value for attributes=[ExpireTime]
  • 2.  RE: How to Configure 802.1X with AD Authentication and Per-User Device Limits in Aruba CPPM?
    Posted 6 days ago
    You need to update the endpoint with the username after a successful authentication. Then you can utilize the Authorization:[Endpoints Repository]:Unique-Device-Count attribute to set your desired device count. The Endpoint Repository needs to be selected as an authZ source in your service.
    ACEX #137
  • 3.  RE: How to Configure 802.1X with AD Authentication and Per-User Device Limits in Aruba CPPM?
    Posted 6 days ago
    I'm not very familiar with CPPM configuration.
    I set the Enforcement policy to Authorization:[Endpoints Repository]:Unique-Device-Count less than 2,
    but if the device hasn't been authenticated before, there is no count in the Endpoints Repository.
    How should I set this up?
  • 4.  RE: How to Configure 802.1X with AD Authentication and Per-User Device Limits in Aruba CPPM?
    Posted 6 days ago
    You can't restrict it on the first authN attempt as CPPM doesn't know anything about the client. However, when the client authenticates you can send back the Endpoint Username attribute with the value of the username used as shown below. This will get added to every Endpoint that the user authenticates from. CPPM will tabulate it automatically.
    Then all that is required is the rule that you used in your post.. FYI less than 2 is going to match on 1. So, you can't use that. Use GREATER THAN OR EQUAL to 2
    ACEX #137
  • 5.  RE: How to Configure 802.1X with AD Authentication and Per-User Device Limits in Aruba CPPM?
    Posted 5 days ago
    That's going to restrict the maximum number of unique endpoints that can be tagged with that specific username.  Important to note that behavior as it requires manual intervention or clean up of an inactive endpoint entry for any other device to be used by that user.
    If the goal is a maximum of two concurrent connected devices for that user, then you need to use queries against Insight to retrieve the number of currently active sessions and allow/disallow based on that value.
    ARUBA VERSION
    New filter "Custom-ConcurrentSessions-PreAuth-User" to find concurrent sessions currently active through interim accounting updates
    To be used in role mappings for Application/WebAuth where %{Authentication:Username} will exist
    SELECT count(distinct calling_station_id) as active_sessions
    FROM radius_acct
    WHERE end_time IS null
    AND username = '%{Authentication:Username}'
    AND LEFT(ssid,LENGTH('%{Application:WebLoginURL:essid}')) = '%{Application:WebLoginURL:essid}'
    AND updated_at > now() - interval '12 minutes'
    - active_sessions: ActiveSessions-PreAuth-User, Integer
    ARUBA VERSION
    New filter "Custom-ConcurrentSessions-User" to find concurrent sessions currently active through interim accounting updates
    To be used in role mappings where %{Authentication:Username} will exist
    FROM radius_acct
    AND ssid = '%{Connection:SSID}'
    AND calling_station_id != '%{Connection:Client-Mac-Address-NoDelim}'
    - active_sessions: ActiveSessions-User, Integer
    ARUBA VERSION
    New filter "Custom-ConcurrentSessions-Endpoint" to find concurrent sessions currently active through interim accounting updates
    To be used in role mappings where %{Endpoint:Username} will exist
    FROM radius_acct
    AND username = '%{Endpoint:Username}'
    - active_sessions: ActiveSessions-Endpoint, Integer
    Carson Hulcher, ACEX#110
