2. Configure ECV-1 with advertise-only static routes for the 11.11.11.0/24 subnets into OSPF with a metric of 51.
can I Configure Adding route on ECV-1
subnet/mask: 11.11.11.0/24
next hop: leave blank as it is advertise only route
interface:
metric: 51
tag: any
will this solve?
Original Message:
Sent: Mar 11, 2025 04:19 AM
Subject: how to configure advertise-only static routes into OSPF with a metric of 51
There are a few things to consider here. First, the most significant route will be preferred over metrics and AD's Check to see what routing protocol is advertising your destination subnet from ECV-2 and ECV-3. Check what parameter (AD, metric, peer priority) is the tie breaker in favour of ECV-3 and adjust accordingly to prefer ECV-2
To redistribute info from one routing source into the other use distribution maps
Original Message:
Sent: Mar 11, 2025 03:46 AM
Can anyone help
Original Message:
Sent: Mar 10, 2025 05:21 AM
Dears,
I have two questions
- How can I configure ECV-1 must prefer the metric of SD-WAN fabric subnet shared routes that originated in OSPF from ECV-2 over those from ECV-3.
- Configure ECV-1 with advertise-only static routes for the 11.11.11.0/24 subnets into OSPF with a metric of 51.
Kindly guide in steps through GUI
