Thanks that worked when I issued:
(MM1) [00:0c:29:46:88:ba] #cd VMC1
(MM1) [00:0c:29:13:d8:8e] #configure t
Enter Configuration commands, one per line. End with CNTL/Z
(MM1) [00:0c:29:13:d8:8e] (config) #interface mgmt
(MM1) [00:0c:29:13:d8:8e] (config-submode)#ip address 10.0.0.247 255.255.255.0
WARNING: Management VLAN Interface will be updated.Connectivity to the management interface will be lost for a moment.
(MM1) ^[00:0c:29:13:d8:8e] (config-submode)#end
(MM1) ^[00:0c:29:13:d8:8e] #wr
Martijn van Overbeek
Architect, Netcraftsmen a BlueAlly Company
Original Message:
Sent: Sep 26, 2024 06:27 AM
Subject: How to configure management interface on a Conductor managed Virtual Controller
Use CLI on the conductor. Set default to VMC and configure mgmt interface from there.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Sep 25, 2024 07:05 PM
Pretty sure that the only option for configuring the management interface is through CLI. The management interface has, historically, been fairly useless and unused.
Carson Hulcher, ACEX#110
Original Message:
Sent: Sep 25, 2024 10:50 AM
I have setup a virtual testlab that looks like below. I am trying to add a management interface. Through disaster recovery mode I can do it but I haven't been able to find if it is also possible through the conductor gui.
Does anyone know? My setup is as below.
