Wired Intelligent Edge
How to configure multiple static IP binding DHCP - Aruba 54016 KB.16.10.0009
This thread has been viewed 19 times
  • 1.  How to configure multiple static IP binding DHCP - Aruba 54016 KB.16.10.0009
    Posted Jul 04, 2022 12:56 PM
    Hi All,
    I would really appreciate if some one can help me with this issue.
    I am trying to configure multiple static bindings in a DHCP pool using below command.
    static-bind ip 172.20.91.11 255.255.255.0 mac xxxxxxxxxxx
    static-bind ip 172.20.91.12 255.255.255.0 mac xxxxxxxxxxx
    static-bind ip 172.20.91.13 255.255.255.0 mac xxxxxxxxxxx
    static-bind ip 172.20.91.14 255.255.255.0 mac xxxxxxxxxxx
    static-bind ip 172.20.91.15 255.255.255.0 mac xxxxxxxxxxx
    but the Aruba OS only takes only one reservation. i.e the last last reservartion, in this case it is 172.19.91.15 reservation.
    I would really appreciate if some one can help me to configure all the reservations.
    Thank you and Regards.,
    Gayan
  • 2.  RE: How to configure multiple static IP binding DHCP - Aruba 54016 KB.16.10.0009
    Posted Jul 04, 2022 01:48 PM
    See here: https://www.networktasks.co.uk/environments/hp/provision/dhcp-server-on-hpe-aruba-switch
    You will need to create a pool for every device you want to set a reservation for. The last one entered in a pool will replace the previous one if you do not.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: How to configure multiple static IP binding DHCP - Aruba 54016 KB.16.10.0009
    Posted Jul 04, 2022 11:14 PM
    Hi Dustin,
    Thanks a lot for your reply.
    Is there any limitation for number of DHCP pools that we can create in Aruba OS. We need to create about 400 different pools.
    Thank you,
    Gayan
