Wired Intelligent Edge
  • 1.  How to configure port based MAC Auth in 2930M switch?
    Posted May 26, 2020 08:42 AM
    I was able to configure port based 802.1x using the command:
    aaa port-access authenticator <port number>
    without any client-limit. But for MAC Auth, the default for this command is  addr-limit of 1 and it doesn't set MAC Auth to port based as it is still user based
    aaa port-access mac-based <port number>
    I tried using the radius VSA HPE-Port-MA-Port-Mode and this works as expected, but I want to enable this using CLI as some ports are always port based.
    Any idea how to achieve this using CLI? I am not using roles in this deployment.
  • 2.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted May 26, 2020 08:50 AM
    Try these commands:
    aaa port-access authenticator tx-period 5
    aaa port-access authenticator supplicant-timeout 10
    aaa port-access authenticator max-requests 3
    aaa port-access authenticator unauth-period 10
    aaa port-access authenticator client-limit <#> --> include the amount of devices , you want to allow per port
    aaa port-access mac-based addr-limit 5
    aaa port-access mac-based addr-moves
    aaa port-access controlled-direction in
    aaa port-access auth-order authenticator mac-based --> Determines the order the authentication will happen
    aaa port-access auth-priority authenticator mac-based
    Sent from Mail for Windows 10
  • 3.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 01, 2020 09:23 AM
    This is still user based and not port based. "Port based" means only one device need to authenticate using MAC Auth, then all devices will be allowed with full access without authentication.
  • 4.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 01, 2020 01:28 PM
    How does the switch determine which MAC to auth if multiple are available? If all MAC addresses can be authenticated, what's the security benefit to only authenticating one of them?
    I don't believe this use case (1st seen MAC is authenticated, subsequent MACs automatically trusted based on the authenticated MAC) is a supported configuration.
  • 5.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 01, 2020 02:21 PM
    I believe in cisco world, this concept is configurable under
    authentication host-mode multi-host
    The first device is authenticated, then all subsequent devices are automatically authorized.
    Being honest, I never understood the use case for that, but I don't think Aruba has a equivalent command, I think every MAC connected to a port  gets authenticated separately
  • 6.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 01, 2020 04:01 PM
    This is possible if you apply role-based access on the switch and you use port-mode under the user-role definition. This is documented here https://community.arubanetworks.com/aruba/attachments/aruba/CampusSwitching/4032/2/ArubaOS-Switch%20User-Based%20Tunneling%20Technical%20Whitepaper.pdf on page 20
  • 7.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 24, 2020 04:46 PM
    I need radius server to be configured with this attribute. Customer was looking for something equivalent to Cisco "multi-host" command but couldn't find any equivalent command.
  • 8.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Jun 24, 2020 05:08 PM
    Hi Ahmad,
    You can create a local user role on the switch that has the port-mode.
    Spoiler
    aaa authorization user-role name "LOCAL_DEMO_ROLE"
    device
    admin-edge-port
    port-mode
    exit
    If you don't watch to do authentication with radius, you can even assign this as the initial role
    aaa port-access <PORT-LIST> initial-role <ROLE-NAME>
  • 9.  RE: How to configure port based MAC Auth in 2930M switch?
    Posted Feb 05, 2025 11:50 AM
    Edited by MARTIN-EXA Feb 05, 2025 11:51 AM
    @cclemmer This solution is needed when you plug an AP on your switch which might be authenticated. In this case, AP authenticate on port and then connected wireless user only authenticate on AP but not on switch.
    Martin
