Comware
  • 1.  how to disable intervlan routing in hp5500 L3 Switch
    Posted Nov 02, 2020 08:08 AM
    Hi team I need to disable intervlan routing and only have to allow one server from management vlan. So pls provide the solution for the same.
    I ahve total 15 vlan
    1) Nedd to disable Intervlkan routing
    2) Only have to allow single server from management vlan
  • 2.  RE: how to disable intervlan routing in hp5500 L3 Switch
    Posted Nov 02, 2020 08:10 AM
    Hi @AshishKumarS !
    You can't disable inter-vlan routing on L3 switch. If you need to restrict access between hosts in different VLANs, use ACLs on Vlan-interfaces.
  • 3.  RE: how to disable intervlan routing in hp5500 L3 Switch
    Posted Nov 03, 2020 12:59 AM
    Hi could you assist me to how to configure acl to restrict for
    communication to other vlan
  • 4.  RE: how to disable intervlan routing in hp5500 L3 Switch
    Posted Nov 03, 2020 06:20 AM
    Is there anything wrong with the guide I shared?
